babock
Feb 10, 2020Explorer
westernrvparkowner wrote:Exactly. And with mine, since I have an EMS, you will never plug it in live unless the EMS is in bypass mode. Just make sure everything is off when you unplug. Not a big deal.
It really doesn't hurt anything to just plug in your RV without switching off any breakers. If there is already a 30 amp outlet on the side of your house, I wouldn't do a thing other than use it. If it bothers you to plug and unplug your rig with the circuit live because you think you will somehow damage something in the RV, just switch off the main breaker in your RV before you plug or unplug, exactly the same as flipping off the an outside breaker. That way you don't have to buy anything or wire anything up.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
