wolfe10
Aug 28, 2013Explorer
To summarize:
If you have a neutral, all would be fine (you need a hot, neutral and ground for either 20 or 30 amp service).
Wiring the hot for the 20 amp outlet from one leg and the 30 amp from the other leg would be preferable, particularly if you ever want to use both at the same time.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
