Danger_Zone's avatar
Danger_Zone
Wiring Disaster
I recently overloaded my system. Afterwards, the generator would power on but my outlets, roof AC, and microwave had stop working. I took my RV to a “specialist” and it was a big mistake. I quickly realized that this mechanic didn’t know what he was doing. Since the generator was running, but not providing power he said he had to change the 12v 120 White-Rogers solenoid, and a 40 amp circuit breaker. While I was waiting I heard him scream. He stumbled out the RV and said he shocked himself. I asked him if he disconnected both batteries and he said no, only the house battery. He then said I didn’t have to pay him and he didn’t feel comfortable touching the RV again because he was badly shocked. When I got back into the RV I noticed wires incorrectly hooked up and my generator would not start. From a picture that I had took months earlier, I was able to figure out where some of the wires went, but there are three wires I am unsure about. I have tried a few combinations but I have not had much luck getting the generator to start. The generator lights up but now it trips the breakers every time I try to start it. Everything else works in the house part. I have not been able to find any house battery wiring diagrams that explain what goes into each circuit breaker.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    CA Traveler wrote:
    Actually a built in RV generator should have a bonded neutral and ground.
    Should have? Say who. Mine did not. Neutral floated. I know cause it "Bit" me.. (Well slight tingle) annoying more than painful. but it very clearly was NOT bonded.
    So what happens when they do not bond?
    The hot/ground/neutral divide the voltage so 120 volts Black to White but 60 volts either of those to Green/Bare
    Why is is not all that dangerous.. Well the capacitive divider can not pass enough current to kill you or so they say it can however cause you to move in such a manner you wind up dead.
    Or otherwise injure yourself
    If you know the joke that involves a new playful kitten
    A man takign a shower and a wife who does not know how to
    Press the button on the garbage disposer.
    WELL then you understand the dangers of sudden movement (HE KIO-ed himself)
  • Actually a built in RV generator should have a bonded neutral and ground.
  • MEXICOWANDERER wrote:
    A generator is a generator.
    Anyone who rents anything from 10,000 watts to 1 megawatt gas knowledgable repair people. I would need 20,000 words to erect an analysis troubleshooter which is just too lengthy.
    It may be something as simple as a grounded neutral.
    Grounded Neutral ??? Correct term is Grounded conductor or Neutral, and why is that a problem?
  • A generator is a generator.
  • X2 Drew. I'd be inclined to get an experienced RV repair preson who is familiar with your rig. Many electricians are not familiar with either RV 12V DC or even RV AC systems just like many RV techinicans aren't familiar with AC.
    You don't have to pay him - REALLY??? I'd be looking to the pros and cons of HIM PAYING all of your repair costs. Just in case start a log and pictures.
  • Assuming these are breakers for the 120V AC system, you plainly have some sort of a short circuit there, such as a miswired transfer switch or (if you have to plug the shore power cord into a generator socket) a miswired generator socket, and perhaps some other AC wiring problems as well.
    Frankly, I don't think this is something that is practical to troubleshoot and diagnose safely over an internet discussion forum. I very strongly suggest you find an electrician or at least someone who is very well versed in AC wiring to help you out. It would be well to double-check that the AC ground wiring is intact and not somehow improperly interconnected with the hot or neutral lines.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 15, 2025
