Shipper
Dec 27, 2019Explorer
I used a volt meter set to 20 volts and read 9.5 volts. I thought the white was positive (14 ga wire) and the black was a 18 or smaller. I have always thought that white was opposite on 12V and 120v. When I reversed the wires the blue pairing light came on but just long enough to screw the camera back in. I did check the camera with the monitor and all worked. The wires are so small its possible they came loose or I did reverse polarity and damaged the camera. I will remove it again and check with the monitor. Many of the reviews said it was a 15 minute job and Ive probably spent more than 2 hours with more to come. It has one more chance before I trash it and do without.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
