dougrainer
Dec 29, 2019Nomad
Shipper wrote:
I used a volt meter set to 20 volts and read 9.5 volts. I thought the white was positive (14 ga wire) and the black was a 18 or smaller. I have always thought that white was opposite on 12V and 120v. When I reversed the wires the blue pairing light came on but just long enough to screw the camera back in. I did check the camera with the monitor and all worked. The wires are so small its possible they came loose or I did reverse polarity and damaged the camera. I will remove it again and check with the monitor. Many of the reviews said it was a 15 minute job and Ive probably spent more than 2 hours with more to come. It has one more chance before I trash it and do without.
The clearance lights usually have a 4 to 6 inch pigtail and will be Black and White or even Black and Black and White and White. Are you positive these wires you see are just the Light pigtails and those are then connected farther in the upper back wall to the main light harness of the trailer? Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
