swimmer_spe's avatar
swimmer_spe
Wiring issue possibly resolved
Remember the issue I had with the brand new battery seeming to die on my trailer?
So, I decided to replace the top post terminals with the eye terminals.
The old terminals were loose. After removing them, there was... rust. Likely from the dissimilar metal of the clamp and bolts.
It ain't fixed yet, but next trip in, I will need to clean the rust off and then put the new terminals on. Likely good to go after that.
  • MEXICOWANDERER wrote:
    He may be describing
    RV battery lugs are the pits. Weak, and stupidly designed.
    This is BY FAR the best terminal design
    With the best stud nut stainless steel just like the studs
    And for the complainers about chintzy thin ring terminals. These babies are THREE TIMES as thick
    These are in fact what I was referring to.
    Lesson learned.
  • He may be describing
    https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29925295/gotomsg/29927860.cfm#29927860
    Please clarify between which "posts" were "loose" and the usual house battery that has both a fat lead post that takes clamps, and a threaded bolt that you put a "ring" lug terminal on and tighten down with a nut or wing nut.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
