time2roll
May 02, 2014Nomad
The incoming power connect Hot (black) to the main 30a breaker, Neutral(white) to the Neutral bus, Ground(green) to the ground bus. Yes the ground bus should have a separate wire from bus to the RV frame.
The 15a is a branch circuit to feed accesories or converter. Connect hot to the breaker and neutral/ground to thier respective bus.
Insert more branch circuit breakers before you double up on anything.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 12, 2026
