Hello, I have recently purchased a motorhome that had a Heart Interface converter/inverter. The converter/inverter was bad so I eliminated it and will purchase a new charger/converter. My problem is n...
The inverter has an internal transfer switch that satisfies that function. If you wire direct then you will have no 120 volts on those outlets when shore power is off.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
