Hello, I have recently purchased a motorhome that had a Heart Interface converter/inverter. The converter/inverter was bad so I eliminated it and will purchase a new charger/converter. My problem is n...
As Mandalay posted, your original inverter/charger probably had an internal transfer switch. The now inoperable 120V powered items were wired through that transfer switch and are now not connected to the grid. You should be able to wire the inoperable circuits directly from your load center.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
