Hello, I have recently purchased a motorhome that had a Heart Interface converter/inverter. The converter/inverter was bad so I eliminated it and will purchase a new charger/converter. My problem is n...
Yup, if you are knowledgeable and safe working around 120 VAC, wire the 120 VAC input to the inverter/charger to the output 120 VAC from the inverter/charger.
As already posted, this will give you power when you are on shore power.
You will also need to make other arrangements for charging the batteries, as that was the other function of the inverter/charger.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
