Ron3rd
Jul 17, 2014Explorer III
2oldman wrote:
If your 12v run is less than 6', you should be fine snipping wire strands. According to the manual, anyway, and the guy you spoke to.
Funny thing is, according to the manual, you should run 4, 6, or 8 gauge wire depending on the length of run. No way will any of those sizes fit directly to the inverter and it seems it's not really designed to be hard wired but is designed to run either of the accessory cables I mentioned in my original post. The set screws that hold the wire in the hole are very small such that you almost need an eyeglass screwdriver to tighten.
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 20, 2025
