DrewE
Feb 20, 2019Explorer III
Vintage465 wrote:
So I totally get the wiring now! This looks easy. Now lets talk amps. Each panel is 18.38v/8.82 amps. Do the amps triple like the voltage? Adding up to a theoretical high of 26.46 amps? Or do the amps stay an 8.82?
I think an analogy here might help. Think of your solar panels as electron pumps, sort of like water pumps. The voltage is the pressure the pump produces, and the current (amperage) the flow of electrons.
If you connect your pumps together in parallel, the pressure (voltage) is the same, but you get three times the flow rate (amperage). If you hook them up in series, one after the other, the same stuff flows through each of them so the flow rate (amperage) is the same but the pressure (voltage) is tripled.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
