time2roll
Oct 09, 2016Nomad
40 amps through that battery connection is fine but you will have losses and slower charging.
You can connect until you figure out how to pull wire to the batteries and also move the controller close to the batteries. Or you may find it is plenty good enough.
Do make sure you are connecting to the 12v side of the panel. Connect same as the converter.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
