BFL13
Oct 09, 2016Explorer II
mike-s wrote:
"With voltage drop the controller will "see" it has reached its high set point , but the battery voltage will be lower than that. This can leave the battery under-charged. "
Not really. The controller will regulate to the absorption voltage, and cut off when current drops below some level or some time has expired. By the time either happens, the current is so low that voltage drop is not an issue. You do loose a small bit of efficiency during bulk charge, when current is at max.
You can argue that with the ASC user's manual guys on the effect of voltage drop between battery and controller;
"A poor connection to the battery will
also distort the battery voltage reading and cause the charging to stop too soon."
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
