Hi Mex,
With respect, my surplus acid AGM telecom units recommend a maximum charging rate of c/5 (i.e. 20%). They are unusual in that the specific gravity is 1.3. They represent a small sub set of the AGM market which are more usually a starved acid design.
I was lucky enough to run into someone on facebook whose job it is to maintain many cell phone tower battery banks. He warned me to not exceed the suggested charging current. It seems to me, the issue may be that surplus acid AGM's may behave in a similar manner to flooded jars when being charged. They may gas--which for a flooded cell is no bad thing but for a surplus acid AGM would not be the best thing to do. I am guessing that exceeding c/5 may cause the jars not just to gas, but also to vent. Of course, that is a big "no no" with a jar where distilled water can not be added.
When the bank is hungry, I do limit the charging current by adjusting the input amperage to the Magnum inverter/charger.
I've had them in service for a year now and am delighted with them.
MEXICOWANDERER wrote:
Someone commented on a 4 ampere constant charge rate for a 10-ampere AGM battery. Snide comments. Ignorant comments. I know of NO absorbed glass mat battery that cannot safely accept a 40% of total amp hour charge amperage that does not exceed 14.4 @ 25c temperature compensated volts. God almighty, the Lifeline group 31 safely accepts NINETY AMPS charge rate. All font on a forum looks the same - beware.
