pianotuna wrote:
Nice Video LY. Thanks!
Yes that is what we see all the time when using our adjustable voltage chargers or different amp settings, but that guy is getting his cause and effect mixed up too. Doesn't matter I guess.
I like how he describes what my ugly graph shows--lower initial amps means higher SOC before reaching Vabs etc. which I got from reading Barre's book.
http://www.bestconverter.com/Books_c_67.htmlEDIT--I watched that second video. The guy keeps saying that many amps are needed to maintain the voltage. Hogwash! It is the voltage that gets you the amps.
The charger has its set voltage. It gets that from the input 120v supply. The amps into the battery do not maintain that. They do raise the battery voltage up to the charger's voltage though. they don't maintain it there--the chemical reaction has taken place. all amps do now is make up for any self discharge. You could say that is amps holding the voltage, but that isn't what he was talking about the way I heard it.
He said the amps went up after he jacked up the voltage because more amps are needed to be at 14.2 than at 13.x. Wrong! The amps went up because the "pressure" (he did use that word) was higher--ie the voltage diff between the charger's v and the battery's v increased, so you got more amps.
What the guy didn't show when he raised the voltage and the amps went higher, is when the battery voltage then gets up to what the charger voltage is now, and amps are tapered again-- except now they might be sitting higher and creating heat because the battery is full.
