77rollalong
Sep 30, 2019Explorer
I find the easiest thing is to use the torch and blow the nut off flush with the manifold, then remove the manifold, then you can remove the studs from the head,, most of the studs now are 8mm, trying to undo them you are more than likely to break them off, then get new studs and nuts.. as they are cheep insurance...
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
