Vacationer04
Oct 10, 2019Explorer II
I finally found a place that would take me in. It didn't turn out as planned. After dropping it off 40+ miles away, they called to let me know that a brake line had ruptured and was leaking brake fluid on their shop floor.
Ok. Maybe I dodged a bullet there but? They had it a week before calling to tell me I could pick it up.
When I arrived, I got told they had to replace my newer lifetime warranty spark plug wires because they were rotten upon removal from the plugs. I had just replaced the plugs a few weeks ago and they were fine then. When I raised an objection to that issue they credited back the cost of the new wires. But they also destroyed my woven boot heat shields that I will have to eat the cost of. My opinion is that they tried to torch the RH manifold nuts without removing the wires first.
When starting to leave the engine had a miss and upon my own inspection, I found 2 wires on the other bank not on the plugs but just shoved in beside them. After I got home, I went to replace the heat shield that I took off while diagnosing the exhaust leak. When I tried to unplug the "new" wires with spark plug boot pliers the right way, on 2 wires the boots just shredded which now will require me again buy a new set of wires. I was taught years ago to use die-electric grease inside the boots on both ends before installing them on the plugs, which was not done by them. At least no broken studs needed to be replaced.
The replacement brake line looks like a blind guy did it the way it was routed. It will function right but looks like hell. My total cost was $947. I wasn't told they automatically add a 2% credit card fee. I found that out after getting in my coach to leave. No Posted Notice to warn you in advance.
My point here is to warn RVers in the area to avoid COMPLETE AUTO & RV REPAIR in St. Charles,MO. Their website looks impressive and the shop looks good, lots of Class As on their lot, but workmanship is less than acceptable.
If I could have gotten access to a torch I could have done this repair myself, so I learned to look farther for assistance in the future.
