dougrainer
Apr 12, 2017Nomad
That light is NOT part of the Workhorse cluster display. That side of the Dash cluster is installed by the OEM. So, that means the switches and indicator lights are for whatever equipment the OEM installed. Have you heard any type alarm or buzzing? You should have HYD jacks. Is the light ON when the jacks are extended and the key is ON? If the light blinks due to a faulty jack down system switch, that would not be enough time for a Jack down alarm buzzer to sound. Doug
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
