rockhillmanor
Apr 24, 2013Explorer II
...dash readout said Reduced Eng. Power.
....Authourized repair facility has never heard of this and there are no fault codes in the computer.
How can they tell you there are no fault codes when there is a dash reading for it? OR did you have it tested and there were no fault codes showing a fault? Either way I'd take it to a 'dealer' instead of just an authorized facility.
Is the light on or off in the gear shift lever for OD when you drop it in reverse?
Good Luck
