Bird_Freak
Oct 13, 2013Explorer II
catkins wrote:Curious if you used the standard wires or the racing set with boots and shields.
I had the very same issue and Taylor plugs did not help. The engine simply still got too hot and fired even them. There is a air dam kit that once installed, solved my problem. Pulls more air into the compartment as you go down the road. Four years and no new issues. Good luck!
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
