tpi's avatar
tpi
Working solar panel vs. idling panel-what changes at panel?
Just a theoretical discussion-
You have a solar panel producing full power to charge batteries. Versus an identical panel on an open circuit adjacent.
The working panel is essentially moving energy from the surface of the panel to the work. The other one isn't. Nothing free in energy transfer.
If you're up on roof observing these panels, what is different about the working panel vs. the idling panel? Is the reflectivity of the idling panel different? Is the temperature of the working panel less? It would have to be something..right? If they were both identical in reflectivity and temperature, then you would be violating some thermodynamic law....?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
