BFL13
May 01, 2018Explorer II
50% might be the limit anyway, since the real lower limit is whether you can still run your electric toaster in the morning without setting off the inverter's low voltage alarm.
With only a pair of 6s that might be at 75% SOC and with four 6s, 50% SOC. Or if you want, you can make your set-up so it would not alarm till lower than 50%, if your RV's size and layout will allow for that.
(Assumes no running the gen or any engine to "support" the voltage for that inverter time)
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
