profdant139's avatar
profdant139
Explorer II
Apr 30, 2018
Working voltage, resting voltage, and the 50 percent rule
Just for the sake of curiosity, I've been trying to determine a correlation between the working voltage of my batteries ( measured while running all of the lights in my trailer) as distinguished from the resting voltage (measured after the battery has been disconnected and has been sitting for a while).
My goal is to try to determine when the battery is really at a 50 percent, since I'm told that we are not supposed to run 12V deep cycle batteries below 12.1 volts, or roughly 50 percent.
So I have two questions: when they say don't run down the battery to below 12.1, that means the resting voltage, right?
And second, is there an accurate correlation between working voltage and resting voltage? For example, if the battery reads 12.2 while under load, does that necessarily correspond to (let's say) 12.4 when resting?
It would be handy to be able to measure the voltage of the battery while in use and come up with a good approximation of the true state of charge, without having to disconnect everything and then wait a while till the battery reaches its resting state. (Usually, when we are camping, I don't have a lot of free time to make those kinds of careful measurements -- DW always wants to hit the hiking trails asap, instead of hanging around and looking at the multi-meter.)
Thanks in advance for your opinions and expertise!
(By the way, these are three year old group 31s rated at 110 amp hours, and the hydrometer indicates that all the cells are doing fine. We have had no trouble with these batteries.)
  • The best idea is to just stop worrying about all that stuff. If you have a continuous battery voltage monitor, just watch it as the day or days progress. You will develop a pattern and learn to live by it.
    In my case, I bought a two decimal point voltage meter from China for about $3 delivered. I connected it to my battery so I could see what it said. I learned to watch it roughly to see how fast it fell, and learned to top up with generator as required.
    Now I have tons of solar, so I never have an issue with our usage.
  • Discharging a lead-acid battery by any amount reduces its cycle lifetime, but 50% isn't any sort of magic number. In fact, for the vast majority of campers, the batteries die because of abuse or their calendar lifetime, not the cycle lifetime. Getting 500 cycles instead of 1000 simply doesn't matter - it's the difference between dry camping every weekend of the year for 5 years vs 10 years, and the vast majority of people simply aren't off-grid that much. Discharging by 80 or 90% a few times a year simply won't make a difference, as long as they're recharged soon, and it's ultimately cheaper than buying more batteries to meet some "50% rule." The 50% thing comes from off-grid daily use, where it does make a difference.
    The other thing which kills them is not recharging them shortly after discharge, or not recharging them fully. The latter happens with the cheap converter/chargers most campers come with. Even the $20 from China eBay solar controllers do better in most cases.
  • You can't get a true "resting voltage" while camping, but you can get a "good enough" version of it by using what I call the "morning voltage".
    Take your voltage in the morning before solar can start to raise that voltage is the first thing. Next thing is to wait till after the furnace has quit for a while and before it cycles back on, and turn off any lights and fans too. Never mind the little parasite draws.
    Ok so that is your "morning voltage" and you can use the usual voltage vs SOC tables for your type of battery. some 12s use 12.2 for 50% Trojan uses 12.1, and so forth. AGMs have higher voltages per SOC. Hard to pin them down, but mine are about 12.4 at 50%. Whatever.
    Now the other voltage you see is the "loaded voltage" and this depends on the size of the amps draw at the time. The higher the amps the lower the voltage. So there is no fixed amount like you were asking about. You can get an idea of the voltage drop to expect for what you have "on" with your rig after a time using it.
    Then if your voltage does not "match" what you would expect, you can go looking for what is wrong. This is good practice, because you need to be able to "tell" when things are "not right".
    If you had a Trimetric, you could cross-check between the AH down from full, and the "morning voltage" to see if they "match" as a good way to see if all is well.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
