Charlie_D_
Dec 25, 2018Explorer
HadEnough wrote:Charlie D. wrote:
Black is probably ABS. Had a leak on my first rig. Used JB Weld and it held for 5 years and still no leak after 5 years
Wow. That's a pretty good result. It's black.
I'll take a look and try the jbweld.
Hopefully it works for you. I made 2-3 layers of buildup. It was cracked where the outlet nozzle attaches to the tank. Because of that there was nothing to cut out and replaced. We were on a long trip and parked in a friends yard and I believe that the tanks, nearly full, added stress to that area. On my first unit it looked like my fresh water tank was sagging, I travel with as little water as possible, I added a piece of pipe bolted to the frame. Flattened the ends. Others have used unistrut or solid or perforated angle
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
