kaydeejay
Jun 04, 2015Explorer
joebedford wrote:NEC code says #8 wire is good for 40A, so that is what I have with a 2-pole 40 amp breaker for plugging in at home.Big Katuna wrote:I hadn't thought of that. Given that it's rarely used in that location 30A per leg would be plenty.
You will never use anywhere near 50A on each leg. Rarely over 25 per leg unless you run microwave, hair dryer and an electric heater.
You could use dual 30 breakers and drop the wire size to 8. You could still run both ACs microwave and fridge.
Local inspector signed off on it.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
