DrewE
Feb 17, 2016Explorer III
The existing wiring is probably sufficient from a safety standpoint, but you may get better performance (particularly when charging) by upgrading it. Figuring out what size it is would be a good idea, of course. You will get much better charging performance with the new converter regardless.
The exiting fuse panel may need a bit of modification or reconfiguration, as it probably has two electrically separate sections. One is fed by the 30A output of the converter (or the battery, when the converter is not active, via a transfer switch of some sort). The other is connected to the battery at all times and may be listed as "filtered" or something similar. The new converter neither has nor needs this transfer switching mechanism, and all the DC circuits and the battery and the converter output are just wired together in parallel all the time (with the appropriate fuses or circuit breakers for protection). The fuse panel modification basically consists of bridging the two separate sections together somehow.
bestconverter.com has some links to descriptions of converter upgrades that may be helpful to you.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
