time2roll
Jul 02, 2022Nomad
Yes very likely the converter has failed. If the battery is original it may also have issues. If you remove a battery cable and the lights go out I say it is the converter as it should operate the interior items without a battery.
A 10+ amp automotive battery charger from a local store should get you through a week or so to get this sorted out. Attach direct to the battery and let it run. Don't forget an extension cord if needed.
Many items in the RV use 12v for the controls even if powered by propane or 120vac.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 18, 2026
