jkwilson
Jul 02, 2022Explorer III
time2roll wrote:jkwilson wrote:My RV thermostat is powered by the RV 12 volt system.bikendan wrote:jkwilson wrote:
Your air conditioner uses 12V too. I suspect your converter has failed or the battery has a shorted cell.
How does an air conditioner use 12v? They are powered by 120v AC power and most thermostats are powered by little AA/AAA batteries.
Most thermostats are not powered by AA or AAA batteries, and even when they are the HVAC is still controlled by 12VDC because the furnace doesn’t use AC power and the thermostat controls both.
OP is having issue with the A/C and low battery voltage.
No need to cover all RVs until the OP has the issue resolved.
Maybe you should address this to the previous poster who believes RV thermostats run on small batteries rather than the person who pointed out that it was likely a 12V battery problem.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 18, 2026
