dougrainer
Jul 05, 2022Nomad
jkwilson wrote:bguy wrote:
Load test the battery.
Would be a total waste of time and effort. The convertor should have more than enough current to run the air conditioner even with no battery installed at all.
Not a waste of time. When fulltime, odds are he has boiled his battery dry and is now DOA. You NEED a good battery for a Power Converter. It helps regulate the DC voltage and also is GOOD for a back up if you have the converter go bad. Puts less stress on a Power Converter when you have a good Battery(Load). Doug
