jkwilson
Jul 05, 2022Explorer III
CA Traveler wrote:jkwilson wrote:I don't consider gaining knowledge a waste and the battery could be shorted which can cause other problems.bguy wrote:
Load test the battery.
Would be a total waste of time and effort. The convertor should have more than enough current to run the air conditioner even with no battery installed at all.
But yes he can disconnect the battery.
A shorted cell would be instantly obvious with a simple voltage measurement. A load test tells you nothing you don’t already know and gives you no useful information. Cranking amps is irrelevant in a deep-cycle application.
