Naio
Sep 05, 2015Explorer II
westend wrote:
Might work but you are probably going to have a 5 lb cheater pipe to spin them up with the weight of the vehicle on them. If you plan to use them on unpaved ground, a board underneath is almost required as they will sink into the ground.
LOL, I would probably need more than that! Maybe a 20' blackpipe :).
@everyone: I want to use the AS JACK STANDS. I don't know why this is confusing! Not as stabilisers, and not as a means of lifting the vehicle.
I would jack up the van using the manufacturer's jack, stick the stands underneath it, and then jack the van down onto the stands and remove the jack. When leaving the campsite, the same steps in reverse.
Exactly what I have been doing with my steel jacks, once or twice a year when blocks don't cut it. I just would like to carry less weight around for that once or twice a year. Is that a reasonable decision or am I going to break my head?
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
