hmknightnc
Jun 24, 2013Explorer
2000Watt will/should run everything except the AC. That generator is likely to be a little on the load side but not too bad so it depends on where you plan to use it. In a quite setting it probably won't be appreciated but rallys, fairs, race tracks, tailgates and etc it should be fine.
Giving it away slightly used better be less than $150.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
