Seon
Feb 21, 2018Explorer II
Wow Loud Genset
Fired up the genset on my recently acquired 2000 Itasca to check out the LED 32" TV I installed and WOW, is it ever loud. So loud that I had to turn up the TV volume in order to hear it. It's not the...
I consider the convenience of a remotely started built-in RV generator fueled from the main tank to be just about priceless. I'd certainly try everything in the book to quiet it down before eliminating it. Your built-in generator may be the most expensive single item in your coach ... it should be made to be as usable and tolerable as possible.
