AH64ID
Mar 11, 2014Explorer
You should be able to do it just as you described, positive to the switch and negative to the load side of the shunt. Just make sure that the wiring from the batter to the switch/shunt is of adequate size.
I just did a similar install with a Xantrex X-Power 1500 and have the positive coming off the cutoff switch, thru a 150A fuse, directly to the inverter and the negative goes directly from the load side of the shunt to the inverter.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
