mchero's avatar
mchero
Xantrex Freedom 458 issues
Our 07 Discovery has a Xantrex Freedom 458 that currently has a control board issue. The remote panel is good (tested with like inverter) but not communicating with my Xantrex. I can't control the inverter via the remote panel or the buttons on the inverter. When connected to shore power the converter will charge the house batteries and when disconnected will invert. I'm going to purchase a new control board in the near future.
The problem I'm having is that the converter will NOT fully charge my 4 Interstate house batteries (4 6volt wet cells). I verified this using a proper glass temperature compensated battery hydrometer.
When I was in Quartzsite my Classic charge controller would fully charge them after I programmed the proper charge parameters. The absorb voltage programmed in the Xantrex is not high enough to fully charge the Interstate batteries.
I'm currently under trees so I disabled the charge controller.
What I'm looking for is a programmable charge controller that I can also use to de-sulfate.
Any suggestions?
Thanks
  • I was wondering if the relay could go bad cause when I to to switch on the auxiliary on my control panel next to the main switch in my 06 fleetwood providence 39J I can hear a click noise come from the relay outside in the inverter box compartment ? There are also 3 3amp fuses that plug in where the relay box is at ? Cause my aux won't come on and neither will any lights and nor will my generator even try to start at all even with the other auxiliary start switch that u can hold on with the generator switch and it would usually start the generator if the batteries were to low but now it won't do any thing
    • Minniesfun's avatar
      Minniesfun
      WELL THANK YOU EVERYONE!!!
      GOT IT ALL WORKING AGAIN MT COUSIN 4 GOT TO HOOK UP A POWER WIRE LAST NIGHT WHEN HE HELPED ME CHARGE IT THE BATTERIES LAST NIGHT.  BUT IT WAS FREEZING OUT THERE AND DARK SO IT'S ALL GOOD.  EVERY THING IS GREAT WITH THE POWER NOW AND GENERATOR
