dougrainer
Apr 22, 2017Nomad
I would like to know what you mean by " Proper cables". Those cables are NOT phone type cables. Also, you stated you connected your remote to another 458 and it worked correctly. Can you try connecting THAT other 458 remote to your 458 to see if it operates?. I have never seen a Problem like you have without it being the Remote cable that was either cut/chewed or had corroded ends. Remember, depending on the systems installed the remote cable may NOT run direct from the Inverter straight to the remote panel. It may go thru a Auto Genstart module also or a AC control board module. What I have is a test cable(not a phone cable) that I use to connect the remote direct to the Inverter to verify if the problem is the cable. Doug
