SoundGuy
Dec 28, 2015Explorer
Gerald55 wrote:
Some of Xantrex's smaller inverters explicitly state that they are not bonded and hence you have a floating neutral with ~60V relative to ground.
Seems to me you're confusing G-N bonding a floating neutral output with a particular wiring scheme used in some inverter designs in which the neutral is 60/60 centre bonded so the neutral and ground are intended to always always remain ~ 60 volts apart, thereby eliminating any possibility of G-N bonding the unit. I own a Motomaster branded true sign wave inverter sold here in Canada by Canadian Tire and because it is not a 60/60 neutral center bonded design it can be G-N bonded, which is necessary if I want to feed it's output through my Progressive Industries EMS-HW30C surge protector as the EMS would otherwise detect what it thinks is an "open ground" error and not pass the signal.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
