CT_WANDERER's avatar
CT_WANDERER
Xantrex Prowatt Transfer Switch UPDATE
I have on order a Xantrex Prowatt Transfer Switch, will be here Tuesday. Can anyone tell me how the coil is energized is it from the Inverter power or Line Power? When energized does the coil stayed powered or is it a latching system? IF the coil is energized can it stay under power for long periods. Dose it switch over quickly so a digital cock will not have to be reset every time power is switched between the inverter or line power? Anyone have any input on this?
Thanks Gary
I got the Transfer switch. with no power the inverter feed through the transfer switch. It is double pole double throw. And it does change fast enough that the digital clock doesn't have to be reset. New PSW inverter and transfer switch is installed and I am happy with it so far.
Thanks for all the gave some input to my post.
