MrWizard
Dec 28, 2015Moderator
a correctly wired ATS
will ALWAYS switch both the Hot and Neutral conductors of ALL inputs involved
and the N/G bond or no bond has nothing to do with it
60v between a conductor and ground is safer than 120v between conductor and gound
and the neutral IS a conductor in the circuit
IF you want an inverter with a bonded neutral to use with an ATS for whole house RV use
i suggest you BUY one that specifies that is is wired that way
instead of damaging what you have by doing some wiring mod that is NOT supposed to be
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
