Salvo
Dec 29, 2015Explorer
No, it's not adequate to just use and ohmmeter.
The only way you will know for sure is if you measure voltage. Many inverters have a internal switchable bond. Meaning, when on shore power the inverter bond is open and when using inverter the neutral-to-ground bond is made.
What's wrong with connecting a couple of wires to inverter to verify?
Gerald55 wrote:
That's only a test I can do when the inverter is installed - does the omhmeter test not also work?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
