Gerald55's avatar
Gerald55
Xantrex ProWatt SW inverter neutral bonded to ground?
Anyone out there have the ProWatt SW inverter and were able to determine if the ground and neutral are bonded on the AC output side?
Some of Xantrex's smaller inverters explicitly state that they are not bonded and hence you have a floating neutral with ~60V relative to ground. Some of the other Xantrex products explicitly mention bonding (such as the switched products that can pass through incoming AC with a built-in transfer switch).
I can't find anything on the ProWatt SW though and haven't heard back from Xantrex.
The inverter itself has only a "chassis ground" terminal, so if it's bonded at all, it must be using that ground?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
