jrclark's avatar
jrclark
Xantrex SW3012 with SCP
I have a Xantrex SW3012 with a Xantrex SCP that has worked well since replacing a Xantrex Freedom 458 about 3 years ago. Today all was well until we arrived in Las Cruces, NM. I checked the SCP and it no longer shows the SW3012 as it usually does. I checked the SW3012 and it was operating normally. But the panel does not recognize it. I appreciate and ideas.
  • jrclark - You can also look at getting Xantrex's 808-9010 Remote Adapter. This way you don't need to run a new Cat5 cable, just use the preexisting 4-pin with 808-9010 to work with the SCP.
  • Thanks for the replies. I tried the suggestions and it did not work. So thinking about it I tried a CAT 6 cable and everything is back to normal.
  • remove all power
    wait ten (long) minutes
    attempt to start the inverter with NO batteries
    return battery power
    start the inverter normally
  • 3_tons's avatar
    3_tons
    Explorer III
    First, try a HARD re-boot (shutoff power to inverter for 5-10 sec) to see if display will return to normal...
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
