Islandman's avatar
Islandman
Explorer II
Sep 16, 2016
XHose for Water Supply
Am thinking about replacing my white water supply hose with the collapsible XHose which can be folded up and takes less space when not used. Our regular white drinking water hose is hard to coil up in cold weather and tends to kink sometimes too. Is the material of the XHose satisfactory for supplying drinking water to the RV, or should I continue with the standard white hose?
  • I had two drinking water safe hoses that were flat. one cloth type was totally flat and developed leaks at the edges. the other was sort of normal hose type material and was oblong so it did take up less room to roll it up. those expanding hoses you see on TV seem to me to be a bad idea. turn the water off and they automatically recoil.?? with no backpressure filling a tank souldn't expand?
    bumpy
  • They are alright for filling the tank, but in general they don't last very long when kept under constant pressure. I have a fold flat hose which can then be rolled up (similar to a fire hose). They generally will have a higher pressure rating but I only use it to fill the tank, not for constant pressure. So it has lasted me about 10 years or so.
  • If you're going to use it for potable water, I'd get one that is made from NSF listed materials. You might want to consider the pressure rating a hose has, especially if you plan to have a regulator at the city water inlet (as opposed to at the faucet). Some hose materials can sometimes impart an offensive taste to the water and some can be bothered more than others by this.
    I seem to recall seeing a collapsing type hose somewhere in the past year that was NSF listed and had a good pressure rating. I think it was at an industrial hose supplier. Maybe one of those type of suppliers may have something that will work.
  • One problem I see with those collapsible and flat roll up hoses is that they must always be fully extended regardless of how close the water spigot is to your RV fresh inlet. The site we're on right now for instance, I even have part of our 10' hose coiled up under the coach.
  • Not sure if it wold be a problem for an RV, but seems like those hoses would also have quite a bit of friction loss over a standard hose. This translates into a lower flow rate and less satisfying shower!
  • We had two of those hoses at the house and they don't like having the water capped off. They burst very easy and quick.
  • Does the label state "Approved for potable water use"? If not, no. If it does, use it.
  • Post from April
    I'm always leery of anything 'as sold on TV'. It's usually a great idea but a poorly-made product. If this is just for filling your tank, fine, but if it's for your city water supply, I'd be careful.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 13, 2026
