MNRon wrote:
Sandia Man and Gdetrailer - thanks for your replies. I don’t have a problem using my battery bank to augment my underpowered generator, my current issue is that the Yamaha 2000iS is so weak that to can’t deal with the surge and puts the system into oscillation. IF I can know the softstart would prevent this I’m good with that solution for the amount of AC we typically require.
With all of that said, I do hear the advice I’m being given and am starting to entertain more seriously. Space and weight (as well as cost) make the Onan solution overkill for our need, but maybe a 3k genny is in my future…
Some food for thought you may find useful before embarking on a larger, new generator.
Not all 2000-2200 watt generators are created equal. The older Yamahas and many 2000w generators are known for their lack of inrush current. Inrush current (less than a second in duration) is needed to start an inductive load like an a/c compressor. The Honda 2000-2200's (which Micro Air highly recommends by the way) have repeatedly shown (in realworld use and testing) they have very high inrush current relative to their 2000-2200 watt continuous rating.
As for surge current, many folks confuse inrush current with surge current. They're very different. Inrush current lasts less than a second (typically rated in ms), whereas generator manufacturers can rate surge current anywhere from a few seconds to 30 minutes (Honda). Huge difference between a few seconds and 30 minutes.
Similar performance differences exist with RV a/c units, too. Not all 13.5 BTU (or 15k BTU) a/c units are created equal. Some 13.5k BTU a/c units can have an LRA (locked rotor amp or inrush current) rating as high as 70a, some can be as low as 50a. In addition, continuous current ratings can also vary widely, too---anywhere from 11a - 15a. Purchasing an efficient 13.5k BTU a/c unit can greatly increase the pool of 2000-2200 watt generators that can successfully start, run it. Installing a Micro Air Easy Start in an
efficient 13.5k BTU a/c creates a powerful combination---you'd be hard-pressed to find any 2000-2200 generator that cannot start, run it.
