SoundGuy
Nov 01, 2016Explorer
Dalo wrote:
The Yamaha genny has a 12 volt outlet that puts out 8 amps. Would this be a better way to charge my batteries directly from the generator?
No. That genset 12 vdc charging output is unregulated and can easily result in overcharging your batteries. Instead invest in a good stand alone charger, plug it into the genset, and charge with it. In my case, I simply turned off my crappy WFCO 8955 converter and instead use a CTEK Multi US 7002 to charge the trailer battery. In your case, because you're using a genset as your charging source, you'd be better off with a CTEK Multi US 25000 for much shorter genset runtime. NOCO also offers similar products.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
