time2roll
Nov 01, 2016Nomad
Dalo wrote:Will not hurt a bit. Definitely give it a go while you decide where to upgrade.
OP here, Thanks for all the info. I have a 40 year old Montgomery Wards charger that I keep under my workbench. Label says 10 amp variable rate at 12.6 volts. Still works. I could hook this up to batts while boondocking. Not sure if 40 yr-old technology will help my case. BFL13 says I need at least 14.4 - 14.8 volts for optimum charging. Opinions?
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
