time2roll
Jun 26, 2016Nomad
maria_bettina wrote:Maybe this was not an issue? Getting the generators in sync may have been the issue.
We started the gennies and then the AC. We overloaded them, so we figured out that with our new converter, we need to turn off the main breaker before starting the gennies. Then turn on the main breaker, then the AC. Problem 1 solved.
For easiest start... turn off all breakers in the RV except the main and the air conditioner. Once air is running for a minute then turn on the rest of the breakers.
I assume you have the water heat and fridge set to propane only.
Also if you turn the air off to say run the microwave leave the air off for at least five minutes for the internal pressure to equalize for easier starting.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jan 17, 2025
