johndeerefarmer
Jun 26, 2015Explorer III
Yamaha EF6300isde to run two a/c's
I am looking at the Yamaha EF6300isde to run my 15k and 13.5k a/c's. I am not sure that I understand the electrical outlets on the unit.
With 120V on each leg, how much current can I get from the 4 prong 50A receptacle?
A google search shows several threads that state that they cannot run their two a/c's on the 4 prong 50A outlet but can on the 30A outlet.
The instructions say that you can get the rated current of 45.8A from the 20A and 30A receptacles if you run it with the switch set on 120V. Is this same 45.8A not available on the 50A outlet? If not then can I parallel the 20A and 30A receptacles to get the full rated power?
