- ronharmlessExplorer
- opnspacesNavigator IIICan you sneak in a right angle screw driver?
Harbor Freight - pianotunaNomad III
JimK-NY wrote:
Since you are in a class C, it doesn't matter but you should be able to unscrew and remove the lock from inside the RV. When mine broke, I had no problem finding a replacement at an RV parts store. I never saw an all steel model. Mine has plastic parts on the inside.
Thanks for the reply.
Except that the screen door covers one of the screws. What a 'smart' design. - JimK-NYExplorer IISince you are in a class C, it doesn't matter but you should be able to unscrew and remove the lock from inside the RV. When mine broke, I had no problem finding a replacement at an RV parts store. I never saw an all steel model. Mine has plastic parts on the inside.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
